Salen la primera informacion oficial de ZEN 2 ( Ryzen 3000 Series )
6 años 8 meses antes - 6 años 8 meses antes #1 por Tamalero
www.reddit.com/r/Amd/comments/btf3s9/amd_computex_2019_keynote/
EPYC is coming to Azure Cloud
Rome is launching Q3 2019
Next-gen PlayStation is powered by 'Navi' and 'Zen 2'
Navi is based on 'RDNA' architecture, which is different to GCN
Navi is PCIe Gen4 enabled
RDNA is a clean-slate architecture, similar to Zen. 1.25x performance per clock compared to GCN and 1.5x performance/watt improvement over GCN
RX 5700 family, named in honour of AMD's 50th anniversary
Faster than RTX 2070 by around 10% in Strange Brigade benchmark
Navi launching in July, more information on Navi (prices, products, tech specs) will be unveiled more at E3 on June 10th 2019
More AMD based laptops from major OEMs
Ryzen family 50% modern devices this year (not really sure what this means)
Asus has 30 500 series motherboard designs (B550/X570)
3rd Gen Ryzen info
7nm, AM4 socket, PCIe Gen4 ready
Floating point doubled over Ryzen Gen1
Cache size doubled
15% higher IPC
3rd Gen Ryzen will be available July 7th (7/7)
Ryzen 7 3700X & $329
8 cores/16 threads, 4.4GHz boost, 3.6GHz base, 36MB cache, 65W TDP
ST performance around equal, 28% Faster than 9700K in Cinebench R20 for MT
Ryzen 7 3800X & $399
8 cores/16 threads, 4.5GHz boost, 3.9GHz base, 36MB cache, 105W TDP
Ryzen 9 3900X & $499
12 cores/24 threads, 4.6GHz boost, 3.8GHz base, 70MB cache, 105W TDP
18% faster than i9-9920X for Blender
Up-to 69% better graphics performance for graphics with PCIe Gen4 over PCIe Gen3
56 X570 motherboards will be available at launch
100 motherboards ready for 3rd Gen Ryzen (via BIOS updates)
Las Sorpresas:
12 core 4.6 Ghz por 500 USD 105W tdp
Navi no es GCN.
Salida de productos en la fecha 7/7.
Mas información en productos en E3.
Última Edición: 6 años 8 meses antes por Tamalero.
6 años 8 meses antes #2 por forseti99
El precio es bastante competitivo, falta ver las laptops que salgan con estos procesadores y cuál será la respuesta de intel, con suerte bajarán el precio de sus proces aunque sea un poco.
6 años 8 meses antes #3 por Tamalero
forseti99 wrote: El precio es bastante competitivo, falta ver las laptops que salgan con estos procesadores y cuál será la respuesta de intel, con suerte bajarán el precio de sus proces aunque sea un poco.
Pues el keynote fue vergonsoso para intel.
Lo único nuevo en cuestión de procesadores, es un Corei9 con 5Ghz all turbo y una utilidad de overclock.
Lo único que si llamo la atención fue el procesador de laptops con 8 cores y 5Ghz max turbo.
Obviamente hay que tener cuidado, ya que hasta los mismos papeles de intel dicen que no pueden garantizar su velocidad turbo.
6 años 8 meses antes #4 por pakitos
¿Entonces el 3700X sería lo que en la anterior el 2600X?
Esos TDP se ven rebuenos :ohmy:
6 años 8 meses antes #5 por Tamalero
pakitos wrote: ¿Entonces el 3700X sería lo que en la anterior el 2600X?
Eso parece, los nombres y numero de cores fueron cambiados..
por orto lado.. intel de nuevo en sus pendejadas lol..
fijense lo que dice hasta abajo de la imagen.
Osea, esos benchmarks y supuesta superioridad de IPC es sin ningún parche de vulnerabilidades, bajo benches que favorecen exclusivamente a intel con compilers dedicados para intel, sin números reales.
6 años 8 meses antes #6 por pakitos
lol
6 años 8 meses antes #7 por Passenger
Se ven super atractivos y a un precio irresistible, quien quiera armar o mejorar una PC tendrá buenas razones para irse por la marca roja. En lo personal me interesa saber cómo anda de temperaturas y fan noise, que siempre ha sido el coco de AMD:
6 años 8 meses antes #8 por Tamalero
Passenger wrote: Se ven super atractivos y a un precio irresistible, quien quiera armar o mejorar una PC tendrá buenas razones para irse por la marca roja. En lo personal me interesa saber cómo anda de temperaturas y fan noise, que siempre ha sido el coco de AMD:
los previews dicen que AMD tiene el mismo desempeño que un 9900 de 160W por solo 105W
Tiempo de carga de la página: 0.425 segundos
